Creating a Zwift account will give you access to your free trial - it starts with your first ride. Then download the Zwift app to a computer, iOS or Android device, or Apple TV and get Zwifting. Elevate your experience with the Zwift Companion App.
Hop on Zwift Hub or any other compatible smart trainer or smart bike. Zwift automatically connects to your devices using Bluetooth or Ant+ to simulate the in-game terrain and adjust the resistance to your structured workout.
Select a world. With 11 to choose from, there are plenty of routes for all. Take a ride with a Pacer Group, they go at a specific pace, around the clock. With nine different paces available, there’s a tempo for you. Choose a workout—designed by world-renowned coaches, they're perfect for leveling up your fitness. Do an event. There's always something happening at Zwift, day or night.
Zwift Hub opens up the world of Zwift. Thanks to the smart trainer's automatic resistance you'll feel every climb and descent while the built-in power meter levels up your training.
And it comes with a pre-installed cassette to match the gears on your bike, which you choose at checkout.
Check out our video guide or read on to learn what a cassette is and how to select the right option for your Zwift Hub to match your bike.
You might call them cogs, sprockets or gears. Together the group of them at the center of your bike’s back wheel is called a cassette.
Zwift Hub comes with a preinstalled cassette to match your bike to ensure they’ll work seamlessly together. To know which cassette option you need, count the number of cogs on your rear wheel.
For example, if you have 10 cogs on the rear of your bike, you’ll need the 10-speed cassette option.
Zwift Hub can be ordered with an 8, 9, 10, 11 or 12-speed cassette. If you require a different number of speeds, gear ranges, or use SRAM XD / XDR, you can order your Zwift Hub with no cassette, no sweat.
Sign up to get the latest on sales, new releases and more …
Financing can only be used for Products. You'll still be able to create your free account and begin your 14 day trial after setting up financing and check-out.
We'll walk you through each step.
